Lifted the coil packs and found that it didn't make any change on the 4 and 6 cylinders. I guess I had two cylinders misfiring. I guess this is good and bad news. I knew I was going to have a semi major failure about now. To start looking at a new build, swap the bad injectors, or order a new 777cc set. I'll prolly dig a little deeper to verify the injectors are bad.
